Authentication in ACE Web Probes
Mar 8th, 2010
Has anyone configured 'credentials' in a HTTP Web Probe? I have tried and it doesnt work with a 401 code returned. I can use the same credentials to logon manually to the rservers. So what gives? Is there a 'domain' parameter that can be separately passed for the web server authentication?
-Mahesh
Gilles Dufour Mon, 03/08/2010 - 23:53
  • Cisco Employee,
What kind of authentication does your server use ?
I believe we only support basic authentication.
Take a sniffer trace and see what your server does.
If the basic authentication does not work, you may havez to implement a script to do what you need.
Gilles.
Mahesh Phadnis Tue, 03/09/2010 - 02:06
We use Windows AD integrated authentication. Can you provide me a sample script that can be used for authentication? Thanks.
Gilles Dufour Tue, 03/09/2010 - 06:46
  • Cisco Employee,
Sorry, but I do not have such a script.
And I believe Windows AD will be difficult to implement inside a script.
Not impossible but really complex...and the number one rule of a probe script : keep it simple.
So, you should find alternatives.
Gilles.
