spa400 in spain
Mar 8th, 2010
Hello all,
Finaaly got the callerid partially working on the spa400.
I have 2 of the FXO used the first 1 is a land line and the callerid works good. The second is attached to a gsm gateway and the only thing i get when i recieve calls on this port is annoymous caller. Any ideas?
Also anyone know the correct disconnect tones for spain, the ones that are in a cisco pdf take up to 1 minute to disconnect the line and sometimes dont disconnect it.
Any help is appreciated, thanks in advance
Alberto Montilla Tue, 03/09/2010 - 05:55
  • Cisco Employee,
Dear Sir;
The SPA400 settings for Spain are ok as set by the wizard. I suggest you configure it using the Wizard BETA that is available on this community, as a document.
Alberto
