Where to get Unity license file?
Mar 8th, 2010
I purchased some CUWL Standard licenses, L-CUCM-UWL-PAK.  I registered that PAK number, received the license file, loaded it into my Publisher, and rebooted the Publisher.
Where do I get the corresponding Unity license file to load into my Unity server?  I don't see any option for it on the \go\license page.
Unity version = 5.0(1.0)
Thanks!
Keith
Aaron Harrison Mon, 03/08/2010 - 11:01
  • Community Spotlight Award,
    Member's Choice, May 2015
If I recall correctly, in the CUWL media folder you get a claim certificate with PAK key for Unity. You register this the same way you registered the CCM licenses...
Aaron
Please rate helpful posts...
keith_chilek Mon, 03/08/2010 - 11:35
I received this license electronically.  After some more digging, it seems that I have not received all the PAKs that I should have.  My vendor is checking on it for me.
Related Content
