MAC Address not populating on 6500's
Mar 8th, 2010
I have two cat 6513's tied together via a port-group with a dot1q trunk.  The mac address of a machine is not showing up one 6513 when I do the following commands:
sw6513A#show mac-address-table address 0050.564f.d438
Legend: * - primary entry
        age - seconds since last seen
        n/a - not available
  vlan   mac address     type    learn     age              ports
No entries present.
sw6513A#
sw6513B#show mac-address-table address 0050.564f.d438
        n/a - not available
Active Supervisor:
*  142  0050.564f.d438   dynamic  Yes         10   Gi11/42
sw6513B#
When I do the same for other mac-addresses, if the mac address is directly connected to 6513A, 6513b will respond with the po2 as the port.  Why doesn't the other 6513 not know about this mac address?  If a host on 6513A tries to ping the machine on 6513B, the ping fails.  I need to have the mac show up on both 6513's in one fashion or another.
Thanks!
Jon Marshall Mon, 03/08/2010 - 12:44
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Can you ping the machine on 6513B from that switch ?
Can you ping the machine on 6513B from the the 6513A switch ?
Is vlan 142 allowed on the trunk link ?
Jon
ursshared Mon, 03/08/2010 - 12:53
I can ping the machine from both machines.  I cannot do a traceroute to the machine from either switch.
Jon Marshall Mon, 03/08/2010 - 13:00
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
So you can ping the machine from both switches but not from a client attached to the 6513A switch ?
With a successful ping from 6513A switch what does the mac-address table and arp table on 6513A show ?
Jon
Related Content
