ACS Upgrade Question
Mar 8th, 2010
I recently installed ACS 4.1. I am now trying to restore the ACS .dmp file from my old ACS 3.3.3 version to the new ACS 4.1 server and it is failing.  Is there anyway I can restore an ACS 3.3.3 .dmp file to an ACS 4.1 server using the "ACS Restore feature"?
Justin
jedubois Mon, 03/08/2010 - 16:29
     Unfortunatly a 3.3.3 backup can only be restored to a 3.3.3 ACS.
     To get the database up to 4.1 you will have to install ACS 3.3.3, import the database, then upgrade
     the ACS software to 4.1.  The softwate upgrade will also upgrade the database.
     You can install ACS 3.3.3 on another server, upgrade the database then import the upgraded database
     into your current 4.1 build if you don't want to uninstall your currently 4.1 install.
--Jesse
