4500/4900 Cannot apply Autoqos Policy to etherchannel member
Mar 8th, 2010
I have two 4900M Cisco switches connected together with two 10Gb (CX-4) links in an etherchannel.
The network will have an Avaya VoIP solution running over it.
Only needing basic QoS so I have implemented the Auto Qos feaure as the policy it generates is more than satisfactory for the limited environment of this network.
This is the default (auto generated policy)
class-map match-all AutoQos-VoIP-Control-Dscp26
match dscp af31
class-map match-all AutoQos-VoIP-Control-Dscp24
match dscp cs3
class-map match-all AutoQos-VoIP-Bearer-Cos
match cos 5
class-map match-all AutoQos-VoIP-Control-QosGroup24
match qos-group 24
class-map match-all AutoQos-VoIP-Control-QosGroup26
match qos-group 26
class-map match-all AutoQos-VoIP-Bearer-QosGroup
match qos-group 46
class-map match-all AutoQos-VoIP-Bearer-Dscp
match dscp ef
class-map match-all AutoQos-VoIP-Control-Cos
match cos 3
policy-map AutoQos-VoIP-Input-Dscp-Policy
class AutoQos-VoIP-Bearer-Dscp
set qos-group 46
class AutoQos-VoIP-Control-Dscp26
set qos-group 26
class AutoQos-VoIP-Control-Dscp24
set qos-group 24
policy-map AutoQos-VoIP-Input-Cos-Policy
class AutoQos-VoIP-Bearer-Cos
set qos-group 46
class AutoQos-VoIP-Control-Cos
set qos-group 24
policy-map AutoQos-VoIP-Output-Policy
class AutoQos-VoIP-Bearer-QosGroup
set dscp ef
set cos 5
priority
police cir percent 33
class AutoQos-VoIP-Control-QosGroup26
set dscp af31
set cos 3
bandwidth remaining percent 5
class AutoQos-VoIP-Control-QosGroup24
set dscp cs3
set cos 3
class class-default
dbl
It allows both the AutoQos-VoIP-Input-Cos-Policy and AutoQos-VoIP-Output-Policy policies to be applied to any interface, however when attempting to apply this to one of the two TenGigabit interfaces which are members of the Etherchannel between the switches it refuses to apply the Output policy saying "non-queing policies must be applied to the virtual port", trying to apply the exact same policy to the Etherchannel it again refuses saying "queing policies must be applied to the physical interface"
Looks like it's going around in circles!
Admittedly the way the network has been designed there will actually be very light usage of the 20Gb link however I know it's somthing the customer will pick up on!
Any ideas?
Tony
Jon Marshall Mon, 03/08/2010 - 12:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Tony
Which IOS version are you running. There are known issues with applying auto-qos to an etherchannel with the workaround being to apply the QOS configuration manually ie. you need to configure the QOS policy and then apply it.
Jon
aiwapro09 Tue, 11/30/2010 - 10:48
Was this resolved?
I have the issue.  I attempted to follow the workaround, and it gave an error as well.  There was another thread about this, https://cisco-support2.uat3.hosted.jivesoftware.com/thread/2008852?decorator=print&displayFullThread=true#2008852 , and I have the same problem as that person did.
Here is what I get trying to enter the commands:
router(config-if)# service-policy input AutoQos-VoIP-Input-Cos-Policy
% A service-policy with non-queuing actions should be attached to the port-channel associated with this physical port.
router(config-if)# service-policy output AutoQos-VoIP-Output-Policy
router(config-if)# interface Port-channel1
% A service-policy with queuing actions can be attached in output direction only on physical ports.
