auth-fail VLAN vs Guest VLAN
Answered Question
Mar 8th, 2010
Hi All,
What criteria is used to determine whether to use the auth-fail VLAN or the guest VLAN?
What if a non-802.1x client connects to the port, say a Vendor.... 802.1x doesn't occur, so does it then transition to guest vlan?
What if a vendor brings in an 802.1x capable PC and connects it... the auth fails, but I'd want the vendor to go into the guest VLAN anyway, Could I give them a temporary username / PW maybe to authenticate with? hmmm...
Thanks in advance.
Correct Answer by jedubois about 6 years 11 months ago
     The Auth-Fail VLAN is invoked if an Access-Reject is received from the Radius server for the
     user or machine authentication.  The Auth-Fail VLAN will be invoked after a number of failures
     not after the first authentication failure.  This is a configurable value.
     The Guest VLAN is invoked if not EAPoL traffic is received from the connecting client.
     You can set the Auth-Fail VLAN and the Guest VLAN to the same VLAN ID if you want
     users who come in with the supplicant disabled or someone with invalid credentials (or no credentials).
--Jesse
Overall Rating: 5 (1 ratings)
Correct Answer
jedubois Mon, 03/08/2010 - 16:26
--Jesse
