IPS password reset via ASDM
Answered Question
Mar 8th, 2010
  • Bronze, 100 points or more
The username/password has been lost to our IPS module.
I used the ASDM menu option to reset the IPS password but nothing happened other than the IPS module resetting.
Is there something more I need to do to reset the password on the IPS module other than selecting "reset IPS" in ASDM?
Tks
Frank
Correct Answer by gunitsgulati about 7 years 4 months ago
No is does not wipe the config, it just resets the module and next time you login with the default username and password
Please do put the results so as to help others, researching on similar topics
Thanks and Regards,
Guneet Singh Gulati
Overall Rating: 5 (1 ratings)
gunitsgulati Mon, 03/08/2010 - 21:11
For IPS (AIP-SSM) v5.0 you have to do complete recovery of the module to reset the password, but for IPS (AIP-SSM) V6.0 and above you can do that from command line using command.
CiscoASA#hw-module module 1 password-reset
With IPS (AIP-SSM) v5.0 on the ASA the command will still be applicable but will end up giving following error message.
The SSM application version does not support password reset
Failed to reset the password on the module in slot 1
Guneet Singh Gulati
fsebera Tue, 03/09/2010 - 05:21
I have IPS ver 6.0 (6)E3
Hardware is ASA-SSM-20
PRODUCTION-ASA# hw-module module 1 password reset
Does this just reset the password on the IPS module and NOTHING more or does it wipe the IPS config also?
Thanks again
Frank
Correct Answer
gunitsgulati Tue, 03/09/2010 - 06:03
Thanks and Regards,
Guneet Singh Gulati
fsebera Tue, 03/09/2010 - 12:06
Tasks and results
PRODUCTION-ASA# hw-module module 1 password-reset
PRODUCTION-ASA# sess 1
Card in slot 1 did not respond to session request
WAIT 5 MINUTES
Change password prompt appears.
The password I entered was refused, then received following error:
Authentication token manipulation error
Remote card closed session
Command session with slot 1 terminated
MUST enter current password first  (I.E.cisco), enter, enter your new password.
Only issue is now the username is the default --- Cisco
Must manaually change the username.
Frank
