IPSec VPN and MTU
Mar 8th, 2010
I am crurrently experiencing the following problem:
I have a site to site VPN configured that used to work perfectly. Now suddenly  I am experiencing that the 1st phase of the VPN process comes up but the second phase does not.
When I issue a "debug crypto ipsec" I get the following feedback (for securty reasons I have altered the IP address):
IPSEC(key_engine): got a queue event...
IPSEC(spi_response): getting spi 0x4789c6b(75013227) for SA
        from  10.10.197.184 to  10.20.199.114 for prot 3
IPSEC(key_engine): request timer fired: count = 1,
  (identity) local= 10.20.199.114, remote= 10.10.197.184,
    local_proxy= 10.11.131.11/255.255.255.255/6/0 (type=1),
    remote_proxy= DOLO_TETE/255.255.255.255/6/7000 (type=1)
IPSEC(key_engine_sa_req): setting timer running retry <2>
IPSEC(spi_response): getting spi 0x31782214(829956628) for SA
IPSEC(key_engine): request timer fired: count = 2,
IPSEC(ipsec_prepare_encap_request): fragmenting, IP packet <1470> greater than e
ffective mtu 1444
IPSEC(adjust_mtu): decrementing path mtu from 1500 by 0,
  (identity) local= 10.20.199.114, remote= 10.30.72.206,
    local_proxy= 192.168.0.0/255.255.0.0/0/0 (type=4),
    remote_proxy= HQ_Bon/255.255.255.0/0/0 (type=4)
ffective mtu 1188
IPSEC(ipsec_prepare_encap_request): ERROR: unable to fragment packet pktsize=147
0, eff_mtu = 1188
IPSEC(key_engine): reseting mtu to default
IPSEC(ipsec_prepare_encap_request): fragmenting, IP packet <1420> greater than e
ffective mtu 1188
IPSEC(ipsec_prepare_encap_request): ERROR: unable to fragment packet pktsize=142
0, eff_mtu = 1188
ffective mtu 1188
0, eff_mtu = 1188
ffective mtu 1188
0, eff_mtu = 1188
ffective mtu 1188
0, eff_mtu = 1188
ffective mtu 1188
0, eff_mtu = 1188
ffective mtu 1188
0, eff_mtu = 1188
ffective mtu 1188
0, eff_mtu = 1188
ffective mtu 1188
0, eff_mtu = 1188
Note: Their are other VPN tunnels on the same device and they are all working OK. The VPN tunnel that is giving problem is between 2 Pix devices, the only thing that changed is that the internet connectionon on the other site changed from Frame-Relay to Fiber-Optic but this change was done 2 weeks before I start getting this problem.
Everything seems to point that the problem has to do with MTU.
What could be causing the IPSEC(ipsec_prepare_encap_request): ERROR
Screech
nomair_83 Tue, 03/09/2010 - 10:56
  • Bronze, 100 points or more
can u try adjusting mtu to 1440?
urvininocente Tue, 03/09/2010 - 18:00
Nomair,
Problem solved. It seems that the reported MTU error did not had anything to do with the 2nd phase of the VPN not coming up. The 2nd phase was not coming up due to a mismatch between the IPSec interesting traffic access-list ( This was discovered in te debug output of the other Pix).
Screech
