Pix 501 and using PHP includes with domain name
Mar 8th, 2010
I'm really new to using a firewall, and need some help.
I have a leased PIX 501.
When I had this added to my server, my PHP  includes on my website that use the URL <?php include ('http://www.mydomain.com/footer.php');?>
those files show up as not found.
I really don't have the option to make the paths relative, do you have any ideas? My support told me that I can add some rules to the firewall and that should cure this problem.
Thanks!
busterswt Mon, 03/08/2010 - 17:46
You may need to enable DNS doctoring to get this working properly. If you're using static NAT translations you'll need to remove the NAT entry and re-enter it with 'dns' tacked on at the end.
static (inside,outside) 66.55.12.33 192.168.1.33 netmask 255.255.255.255
TO:
static (inside,outside) 66.55.12.33 192.168.1.33 netmask 255.255.255.255 dns
After re-entering the entry you may need to clear the xlate as well.
Good luck!
James
Related Content
