Ciscoworks2000 Compliance check
Mar 8th, 2010
Question: I want to Check Particular command is present in switches through ciscoworks2000.
See i checked that it is possible in LMS 3.1 via RME-Compliace check and i have already did that but  i want to achieve Same function in ciscoworks 2000.
Joe Clarke Mon, 03/08/2010 - 23:32
CiscoWorks 2000 is an obsolete product which is no longer supported.  Is that really what you're running?  What version of CiscoWorks do you have exactly?
digpal.zala Tue, 03/09/2010 - 03:49
I have Ciscoworks 2000 and i want to check that among 40 switches,how many switches are configured with Mac-security? shall i achieve it with the help of any tools or functions of ciscoworks 2000.
Joe Clarke Tue, 03/09/2010 - 22:57
"CiscoWorks 2000" is not a version.  It was the name of a product - a very old product.  In order to provide an accurate answer, I need to know the specific version of Resource Manager Essentials that you have.  If you have RME 3.x, then, no, the baseline compliance feature that that is available in RME 4.x is not present.
