Mar 9th, 2010
Hello, sorry for my english. I need to host have the allocated bandwidth 50kbit in conformity with this acl:
access-list shilova extended permit tcp host any eq www
access-list shilova extended permit tcp host any eq https
access-list shilova extended permit tcp host any eq ftp
What is incorrect?
priority-queue inside
priority-queue outside
csd image disk0:/securedesktop-asa-
class-map class_ftp
match port tcp eq 221
class-map tcp_traffic
match access-list tcp_traffic
class-map shilova
match access-list shilova
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
class class_ftp
  inspect ftp
policy-map QoS
class tcp_traffic
class shilova
  police input 50000
service-policy global_policy global
service-policy QoS interface inside
service-policy QoS interface outside
prompt hostname context
KARUPPUCHAMY MA... Tue, 03/09/2010 - 04:19
Do want to configure Bandwidth limit to the client for 50Kbps.If yes , then you can configure POLICING,which will ensure that the client can access only the allotted bandwidth.
hostname(config-pmap-c)# police {output | input} conform-rate [conform-burst]
  [conform-action [drop | transmit]] [exceed-action [drop | transmit]]
Sample config:
ASA(config)# access-list AL-WEB-TRAFFIC permit tcp host eq www any
ASA(config-if)# class-map CM-POLICE-WEB
ASA(config-cmap)# match access-list AL-WEB-TRAFFIC
ASA(config-cmap)# policy-map PM-POLICE-WEB
ASA(config-pmap)# class CM-POLICE-WEB
ASA(config-pmap-c)# police output 56000 10500
ASA(config-pmap-c)# service-policy PM-POLICE-WEB interface outside
For more information just have a look into the below URL
KpaH4iTooo Tue, 03/09/2010 - 23:27
If the link is loaded, the host leaves with a speed smaller, than 50kbit(
