CME graphical user interface
Answered Question
Mar 9th, 2010
Hello
What is the minimum IOS required and GUI file to run CME on a 2801 Router.
Flash is 64MB.  Is there any other pre-requisite.
ST
Correct Answer by Paolo Bevilacqua about 6 years 11 months ago
Recommend CME 7.1 minmum, any IOS version.
As indicated above, most memory work fine.
Please remember to rate useful posts clicking on the stars below.
Overall Rating: 5 (2 ratings)
saquib.tandel Tue, 03/09/2010 - 01:36
Hello
I do agree what you mean, but on 2801 Flash is 64MB only and loading IOS supporting Voice and full-GUI.tar will not work. ( out of space )
So I was looking for recommendation.
Can you suggest.
saquib.tandel Tue, 03/09/2010 - 02:16
thanks for caring and replying.
Which IOS and GUI file you recommend for 64MB Flash to run CME.
which brand you recommend for external USB, supporting 2801. i am sure are you have experienced on this?
Correct Answer
Paolo Bevilacqua Tue, 03/09/2010 - 02:34
