How bridge group is differentiated from vlan
Answered Question
Mar 9th, 2010
Sir,
we have 2948 G  switch.In that we are using bridge group configration instead of valn.Is  there any advantage available for bridge configauration over VLAN
interface  BVI1
ip address 10.x.x.x 255.255.255.0
no ip directed-broadcast
interface  BVI2
ip address 176.x.x.x 255.255.255.224
Thanks in advance,
Senthil
Correct Answer by Ganesh Hariharan about 7 years 3 months ago
Sir,
interface  BVI1
interface  BVI2
Thanks in advance,
Senthi
Hi Senthil,
Bridge groups provide a method to group two or more ports into a single broadcast domain, where as VLAN's provide a method to group many ports into a single broadcast domain or establish a number of broadcast domains (or secure groups) on a single switch.
Bridge groups operate at layer 2. So they are not very effective at connecting layer 3 switches and routers.If you want to connect 2 ports of a layer 2 switch with 2 Ethernet interfaces of a router you can do that but the Ethernet interfaces on the router no longer operate as routed interfaces.
Check out the below link for more information
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_tech_note09186a0080094663.shtml
Remember to rate the helpful post
Ganesh.H
Overall Rating: 5 (1 ratings)
Correct Answer
Ganesh Hariharan Tue, 03/09/2010 - 02:13
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Sir,
interface  BVI1
interface  BVI2
Thanks in advance,
Senthi
Hi Senthil,
Ganesh.H
