GUI Issue
Answered Question
Mar 9th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
Hello Netpro
I got “CME 7.1(0) Updated GUI files for IOS 12.4(24)T releases” but cannot access GUI interface, no error
page is loading??? for last 10mins, try again same issue. I test on IE 6 / 7 / 8
ip http server
   ip http authentication local
   ip http path flash:
     web admin system name f99 password cisco
Correct Answer by Paolo Bevilacqua about 6 years 7 months ago
The ones in GUI directory.
Overall Rating: 5 (1 ratings)
nasr.khan Tue, 03/09/2010 - 06:06
IP VOICE IOS 12.4(24)T
I get a gray screen with VIEW WINDOW
any clue
nasr.khan Tue, 03/09/2010 - 07:49
Webpage error details, on status bar i get Cisco unified Communication Manager Express but page remains blank
On clicking the ! mark I get this error msg.
Message: Expected ';'
Line: 2567
Char: 14
Code: 0
Message: 'maxC' is undefined
Line: 2685
Char: 11
Code: 0
Paolo Bevilacqua Tue, 03/09/2010 - 11:18
You are not missing anything.
Try cleaning and reinstalling, otherwise switch to YB5 and related fies, I have it working in many sites.
nasr.khan Tue, 03/09/2010 - 11:42
p.bevilacqua Thank You
Clean and reinstall the configuration or IOS Software
what is YB5? I didnt got this??
nasr.khan Tue, 03/09/2010 - 12:19
Thanks bevilacqua
I am downloading c2801-ipvoicek9-mz.124-22.YB5.bin  but which GUI version for CME do you advice and working with you.
nasr.khan Tue, 03/09/2010 - 12:47
Is this GUI Version OK
Release Date:  24/Jul/2008
CME 7.0 GUI file.
Size: 782.00 KB  (800768 bytes)
Which version is working with you???
nasr.khan Wed, 03/10/2010 - 05:53
big TarFile is 70MB and another is 86MB
If you say anyone of these then i would have problem with flash size ( its kinda 64MB only )
If its not this then can you put the exact name or screenshot.
nasr.khan Wed, 03/10/2010 - 08:41
Cannot extract the file on Router, but will extract on a Linux Machine.
What next.
Paolo Bevilacqua Wed, 03/10/2010 - 09:31
Winrar and many other SW handle .tar on PCs.
Then copy to router and test. Must be used with IOS YB5.
agcastle2000 Tue, 03/01/2011 - 03:12
Hi Paolo
What version of IOS 15.x do you know that works with CME GUI 8.0, 8.1 or 8.5?
I'm getting the following error.
Permission denied
ITSMain                                   Line: 1
Code 0                                   Char: 1
I've already tried a lot of them based on IOS and CME Compatibilty Matrix with no success. Like,
c3900-universalk9-mz.SPA.151-1.Tx.bin with CME GUI 8.0
c3900-universalk9-mz.SPA.151-2.Tx.bin with CME GUI 8.1
c3900-universalk9-mz.SPA.151-3.Tx.bin with CME GUI 8.5
Any ideas?
nasr.khan Wed, 03/10/2010 - 11:23
There are so many files after extraction, I cannot copy all due to limited flash.
Which files to copy to the flash.
