SPA942 call forwarding
Mar 9th, 2010
I am having an issue with the SPA942. I am not able to forward calls from the phone to the number I input. The menu will let me input a number and then secs delay but it will not then send the call to the number inputted. The call is simply sent to the default maibox.
I have had a look throught control panel to try and find anything that jumps out at me to change in the setting but no joy.
Any tips would be great thank you.
Adrian
Alberto Montilla Tue, 03/09/2010 - 08:08
Dear Sir;
Not sure I understand your question, do you want to use call forwarding or call deflection? Difference is whether you want to do the forwarding before the call happens on during call ringing...please let me know.
Alberto
innerwolf Tue, 03/09/2010 - 08:40
Alberto
I would like the call the call to ring, I have a delay set for 20 seconds then divert. So it is the CFWD No Ans. I have tried several numbers, it won't work on any. The goal is to have this point to a queuing system that our provider has set up, but it won't direct to the queue number.
I assume there must be something in the control panel that is overriding the divert number.
Adrian
Alberto Montilla Thu, 03/11/2010 - 06:07
Ummm, this should work provided your network server supports the feature (302 message). If you provide me the traces, I should be able to help more on determining the root cause.
Alberto
innerwolf Thu, 03/11/2010 - 06:16
Thanks Alberto
I will check to see that they allow the 302.  How do I go about providing traces?
Adrian
