configuration error with a Cisco ASA 5505
Mar 9th, 2010
I am having some problems with a Cisco ASA 5505 Firewall.
apparently the settings are correct, but from the INSIDE network can not ping a public IP.
Perhaps I am missing something that can not see
The WAN connection is connected on port 0 / 1
Lan on 0/0
This is my configuration:
# show running-config
: Saved
ASA Version 8.2(1)
XXXXXXXXX
names
interface Vlan1
nameif inside
security-level 100
ip address 172.20.10.254 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 190.XXX.XXX.134 255.255.255.248
interface Ethernet0/0
interface Ethernet0/1
switchport access vlan 2
interface Ethernet0/2
shutdown
interface Ethernet0/3
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
ftp mode passive
access-list salida extended permit ip any any
pager lines 24
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 172.20.10.0 255.255.255.0
access-group salida in interface inside
route outside 0.0.0.0 0.0.0.0 190.XXX.XXX.129 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
prompt hostname context
Thank you very much for your help!
PS: excuse my language.
Kureli Sankar Tue, 03/09/2010 - 05:46
  • Cisco Employee,
Trying adding inspect icmp.
inspect ftp
inspect h323 h225
inspect icmp --------------> add
-KS
gilgamezh Tue, 03/09/2010 - 06:14
try  to add, but does not work
Possibly explain me  wrong, I have not actually INSIDE the network connectivity and  Internet.
Kureli Sankar Tue, 03/09/2010 - 07:49
  • Cisco Employee,
I am not sure if I follow you.
Are you saying you are unable to go to the internet from the inside?
can the ASA ping the default gateway 190.XXX.XXX.129 on the outside?
-KS
gilgamezh Tue, 03/09/2010 - 07:55
YES
yes, 100%
I  have a client host with ip 172.20.10.252 and from that computer can not  ping the gateway 190.XXX.XXX.129
gilgamezh Tue, 03/09/2010 - 08:00
I have doubts about the "switchport access"
The WAN connection is  on port 0 / 1 and the LAN on port 0 / 0
my configuration is correct?
interface VLAN1
nameif inside
security-level  100
interface vlan2
nameif outside
security-level  0
190.XXX.XXX.134  ip address 255.255.255.248
interface Ethernet0 / 0
interface  Ethernet0 / 1
Kureli Sankar Tue, 03/09/2010 - 08:02
  • Cisco Employee,
What is the gw for the inside host? Can it ping the firewall 172.20.10.254?
What do the logs show?
conf t
logging on
logging buffered 7
exit
sh logg | i 172.20.10.x
where 172.20.10.x is the host that has trouble going to the internet.
-KS
gilgamezh Tue, 03/09/2010 - 08:29
I just  found the problem!
Call the place  where the ASA Firewall and I discovered that there was a host with the  IP 172.20.10.254.
There is so that the ASA I report  Duplicate IP?
Related Content
