03-09-2010 05:49 AM - edited 03-04-2019 07:45 AM
Is there a limit on the number of GRE tunnels that can be configured on a router?
Any advice welcomed.
Phil
Solved! Go to Solution.
03-09-2010 01:54 PM
Phil
As Lei Tian points out there may be factors such as memory constraints that will place practical limits on how many tunnels you can support. But there is also a hard limit on the number of tunnels that you can configure. That limit is based on the limitation of the number of IDBs supported by your router. The IDB is the Interface Descriptor Block and each interface (physical, or tunnel, or loopback, or whatever) requires an IDB. The number of IDBs will vary by platform and sometimes by release level of the code that you are running. You can use the privileged command show idb to see what the limitation is on your router. On the 1841 router that I just checked the limit on IDB is 1200 (which is a pretty large number - I believe that you would encounter other limits on performance or on size of configuration before you exhaust the IDB limit).
Rick
03-09-2010 07:56 AM
Hi Phil,
I think that is a question depends on platform and IOS version. It is better to test it to find the answer, and you might hit resource limitation other than the number of tunnels, like cpu, memory.
HTH,
Lei Tian
03-09-2010 08:22 AM
What prevents you from using multipoint GRE ?
03-09-2010 01:54 PM
Phil
Rick
