Adding a new subscriber to an existing cluster
Mar 9th, 2010
Hi all,
I am adding a new subscriber server to an existing cluster (1 x Pub & 2x Subs), however, the installation disk I have been sent is of a lower version to the version that is currently running on the cluster. The cluster is running on (Ver 7.1.2) & I have an installation disk with (Ver 6.1). I have never done this before & I have concerns with what affect this could have on the operational servers, as such, I would appreciate any advice or steps I should take to get the server upgraded to (Ver 7.1.2) & operational on the cluster.
Overall Rating: 2.7 (3 ratings)
htluo Tue, 03/09/2010 - 07:44
  • Red, 2250 points or more
You have to use the exact same version to add a server to the cluster.  Otherwise, database replicaiton might be broken.  And it is not supported by Cisco.
Michael
http://htluo.blogspot.com
norrie108 Tue, 03/09/2010 - 07:54
Thanks Michael,
My issue is more with getting the versions to the same level. I'm assuming that during the installation the new sub will need to talk to the pub but my installation disk is ver 6.1. Will I be able to upgrade directly from 6.1 to 7.1.2?
David Hailey Tue, 03/09/2010 - 07:57
  • Purple, 4500 points or more
Most likely not.  You should be able or as Cisco calls it have "entitlement" to order the proper media as an upgrade kit and have it sent to you.
Hailey
Please rate helpful posts!
norrie108 Tue, 03/09/2010 - 08:09
Thanks Hailey/Michael for your reply,
So there is no issue with me going through with putting the ver 6.1 server on the network & going through with the install. I should have mentioned that this server is an old sub currently running an old ver 4.13 on it hence the 6.1 installation.
