DBWalker with Unity 4.0.5 Error
Mar 9th, 2010
We are preparing to migrate to connections and while running DBWalker on the current 4.0.5 server we encounter the following error:
Run-time error '-2147023394 (800705de)':
Error reporting event - The event log file is full.
We've tried upgrading to the lastest DBWalker with no luck.  Also checked the logging folder and it has ample space.  Any suggestions?
Tray Stoutmeyer Tue, 03/09/2010 - 09:02
Sounds to me like your application logs in event viewer are full. Try this in the event viewer to help DBwalker run.
Selcet Application Log, then select Action >>
Properties to open the Application Log Properties dialog. Then select the Overwrite Events
As Needed option and click Apply then OK.
Tray
