Pix 525 and IE8
Mar 9th, 2010
We have a Pix 525 on our network. Never had to upgrade it as it does what it needs to do. However our company is moving from XP(finally) to windows 7. I have tried to get access to the PIX PDM 2.0 using IE8 but it will  not connect. Are there any changes in IE8 that I need to make this work? Any help would be apreciated. Thanks.
John
trippi Fri, 04/02/2010 - 11:13
You need to upgrade the PDM to the ASDM latest version for your particular code.
IE8 broke the earlier versions of PDM/ASDM.
