2960G- 3 ESX hosts
Mar 9th, 2010
hi,
can someone please help verify the following configuration for Cat2960
version 12.2
no service pad
service timestamps debug datetime localtime show-timezone
service timestamps log datetime
service sequence-numbers
hostname SRV-SW3
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone EDT -5
clock summer-time EDT recurring
system mtu routing 1500
ip subnet-zero
cluster commander-address 000a.412c.ca00 member 7 name VT vlan 1
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet0/1 - 19
switchport access vlan 10
switchport mode access
spanning-tree portfast
interface GigabitEthernet0/20
switchport access vlan 3
interface GigabitEthernet0/21 - 23
interface GigabitEthernet0/24
switchport mode trunk
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan2
ip address 10.0.2.249 255.255.255.0
no ip route-cache
ip http server
control-plane
here is an examle of one ESX host
Service Console                VTESX03
IP Address        10.0.0.72  (port 6 on the ESX)--->Port 15 (cisco2960)
                                                              (port 4)--->port 13 (cisco2960)
Subnet Mask        255.255.255.0
Hostname (FQDN)        VTESX03
Gateway        10.0.0.1
DNS Server address        10.0.0.17/10.0.0.18
VLAN ID                10
i don't see int vlan 10 configured on the c2960
customer is saying that his VMs have LAN connectivity but i am not sure how is that possible?
thank you
Reza Sharifi Tue, 03/09/2010 - 12:22
Hello Mohammed,
Do a "sh vlan id 10" and see if the vlan exist.
If the switch is in vtp server mode you don't see L-2 vlans unless you change it to transparent mode.
Reza
