WLC4402 and new DHCP scope
Hello all,
Currently I have WLC4402 and has internal DHCP scope for wireless client.  The problem is this scope is running out of ip address soon and the
bad side is I can not expand this scope since it will conflict with another scopes.  This DHCP scope is same subnet with ASA and the ASA is
acting as gateway for internet traffic.  Let say 172.17.62.0/24 subnet and ASA is 172.17.62.1  Since this scope can not be expanded.  Is there
a way to workaround to setup another scope and using ASA as gateway for internet traffic? Let say 172.17.68.0/24 for new scope.
The WLC current mode is Layer3 operating mode.
Thank you.
dancampb Tue, 03/09/2010 - 12:48
This could work if you created a new dynamic interface for the new subnet and used AP-Groups to apply this interface to certain AP's.  This really isn't a great design though.  The controllers don't support secondary IP addresses.
