Downgrade ACS 5.0 to 4.2
Mar 9th, 2010
Hello all,
i just got my 2 ACS boxes  and they are pre-loaded with ACS 5
My problem is that all my documentation, test plans, schmatics etc were made on ACS 4.2
Am also using feature from 4.2 that are not on 5
I tried downgrading the appliance by booting on the DVD ( ACS 4.2 recovery that came with the box )
my problem is that the setup hang juste after loading the mscdex ( win95 boot )
Since it can boot on the DVD, the hardware is a DVD ( A CDrom would not read a CD )
i cannot get to the 1-2-3 menu... i try burning a copy of the dvd without any luck
Any idea?
jrabinow Tue, 03/09/2010 - 12:02
  • Cisco Employee,
Which features are you missing on ACS 5?
If this is the main issue you may want to consider ACS 5.1 that has additonal features beyond ACS 5.0
conradduval1 Tue, 03/09/2010 - 12:15
Actually, its more all the documentation that i have produce... they are all based on 4.2, all my test plan, printscreen, admin guide etc for my customer.
the actual demo to the customer was made on 4.2
Am also using PEAP-TLS for Auth.. and i saw in some doc that its was not implentated in V5
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.0/user/guide/migrate.html#wp1052549
i didnt look at 5.1 yet
bye
alain.pellmont Thu, 05/27/2010 - 06:21
Hi guys
I had the same problem,the fix is:
serial console 9600,8N1 only with Hyperterminal and it works.
SecureCRT or ZTERM are my faivorites but only Hyperterm worked for this issue.
Cisco Secure ACS: 4.2.0.124
Appliance Management Software: 4.2.0.124
Acs Appliance Recovery Options
  [1] Reset administrator account
  [2] Restore hard disk image from CD
  [3] Exit and reboot
Enter menu item number: [2]
This operation will completely erase the hard drive.
Press 'Y' or 'y' to confirm, any other key to cancel:y
Please wait while Cisco Secure ACS image is restored.
This might take several minutes ..
Alain
Related Content
