Dial-peer and STCAPP
Answered Question
Mar 9th, 2010
I'm at a complete loss on this one, I have an analog phone on which we have been trying to use STCAPP for FAC but in order to start the STCAPP service I need to remove the destination-pattern from the dial-peer, when I do so, the dialtone gets replaced with a busy tone.
All of this is on Cisco 2821 H.323 Gateway (IOS 12.4(24)) using a VIC-4FXS/DID card, the phone number is configured in CUCM 7.1 as a route pattern with the 2821 as the gateway/routelist.
Any help would be greatly appreciated.
Config Details:
stcapp ccm-group 1
stcapp
stcapp feature access-code
call forward all 2
call forward cancel 9
stcapp feature speed-dial
stcapp call-control mode feature
voice rtp send-recv
voice service voip
fax protocol none
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g729br8
voice class h323 1
  h225 timeout tcp establish 3
voice-port 0/2/0
description Phone XXX-XXX-7948
station-id number XXXXXX7948
caller-id enable
ccm-manager config server 172.16.100.12
ccm-manager config
sccp local GigabitEthernet0/0
sccp ccm 172.16.100.12 identifier 1 version 7.0
sccp ccm 172.16.100.11 identifier 2 version 7.0
sccp ip precedence 3
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register NNKCONF
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 9
associate application SCCP
dial-peer voice 7948 pots
description XXX-XXX-7948
destination-pattern 7948
port 0/2/0
Correct Answer by Aaron Harrison about 6 years 10 months ago
There's some info at this URL (for a VG202, but the idea is the same):
http://www.cisco.com/en/US/docs/routers/access/vg202_vg204/software/vg2_vg4_voip_ps2250_TSD_Products_Configuration_Guide_Chapter.html#wp1057036
Looks to me like you don't have dial-peers set correctly, i.e.
dial-peer voice 1 pots
service stcapp
port 0/0
Also when you add the gateway to CCM, add it as protocol 'SCCP', put in the MAC address of the LAN interface you have bound SCCP to, and configure each port with a DN/CSS etc as you would with an IP Phone.
Aaron
Please rate helpful posts...
Correct Answer by Paolo Bevilacqua about 6 years 10 months ago
Analog emulation or something like that.
These will be handled like true phones, not h.323 gateway.
It must be described somewhere in the documentation.
Likely busy tone because registration is unsuccesulf, have you configure an analog emulation phone with the correct MAC on CCM ?
There are also various show stcapp comamnds to verify that.
Overall Rating: 5 (3 ratings)
Correct Answer
Paolo Bevilacqua Tue, 03/09/2010 - 14:39
coconino1969 Tue, 03/09/2010 - 16:17
Thanks for the quick response.
Excuse my lack of knowledge on the matter, I'm still going thru guides on this one.
When selecting the phone type in the drop down menu, which is the one I should be selecting? Right now the only configuration at the CUCM that I have is a route pattern with the extension number. I did that following other FXS analog phones already in place in the CUCM.
Correct Answer
Paolo Bevilacqua Wed, 03/10/2010 - 02:50
Correct Answer
Aaron Harrison Wed, 03/10/2010 - 03:57
service stcapp
port 0/0
Aaron
coconino1969 Wed, 03/10/2010 - 08:19
Thanks Aaron, that was extremely helpful.
Had to scratch the gateway at CUCM and add it as a SCCP 2821, once there I had to configure the modules. The analog ports are now registered with CUCM and the FACs are working.
