VPN client support on the SRP 500 platform
Mar 9th, 2010
I actually really like the SRP 500 platform. However, it is missing a feature that the UC520, the 800 series ISRs, the SA500 series, and Cisco Small Business WRV series routers are not. It is the ability to connect to the router with a VPN client. Even though I can port forward if it is being used with the UC500, there is no way around this problem in a standalone situation. Support for QuickVPN, Easy VPN, and/or AnyConnect VPN clients is a must have if we want to deploy this standalone. Are there plans to support QuickVPN, Easy VPN, or AnyConnect on the SRP 500 platform?
Andrew Hickman Wed, 05/19/2010 - 03:03
Hi John,
Sorry for the late response.
Currently the SRP520 only supports point to point IPSec VPN.
We have VPN server (for Cisco VPN clients) on our roadmap.
Andy
Arash Tabarestani Thu, 10/21/2010 - 09:58
Any Updates on VPN remote access for SRP 500 series ? is it possible to connect with IPSecuritas or any other VPN clients to connect to this platform?
MVermeulen2006 Fri, 06/17/2011 - 21:29
Please let me know if there is an estimated availability date for this feature.
Andrew Hickman Mon, 06/20/2011 - 05:18
Some time early in 2012 is the current plan.
(All plans subject to change without notice)
Thule_rsr Tue, 06/28/2011 - 11:57
So not even the Cicso v5.0 VPN client can connect to an SRP527W?  What's different between that type of connection and to a fixed endpoint?  The option for how to identify the remote end includes 'IP Address', 'FQDN' or 'Any'.  Wouldn't that last one suggest a random remote client?
Andrew Hickman Wed, 06/29/2011 - 09:31
Hi Richard,
The Cisco VPN client works with a Cisco Easy VPN Server, not a standard IPSec peer as we have in the case of the SRP500.
"Any" would allow any compatible remote client to associate.  This would typically be used when the remote router/client uses DHCP to get its IP address.
So just to reiterate, the SRP does not currently have a VPN server feature that would be appropriate for user remote access.
Andy
mattykoch Mon, 11/14/2011 - 17:27
Hi Andy,
Any update on the VPN Server feature for the SRP527W??
Is there any date on the roadmap yet??
Matt
dominik_hassler Tue, 03/06/2012 - 04:39
I have upgraded my SRP521W to the latest FW (v1.01.26) which includes the VPN server functionality. VPN server works w/o any problems.
However there is a feature I am missing which makes the VPN server useless (in my case):
Once the VPN client has connected to the VPN server the connected device has access to ALL VLANs as well as the WAN.
--> is there a feature planned to restrict VPN user's VLAN access (e.g. user1: VLAN1, VLAN3; user2: WAN, VLAN1, etc...)?
aushardworking Wed, 03/07/2012 - 23:46
Andrew - Is there any news on this??
I have just purchased a new SRP527W but still no VPN client support
When I tried to load the firmware that I am running on another SRP527W (1.01.19 (VP004) Jan 7 2011) It failed!!!
I REALLY need the VPN Client Support!  And now have an SRP527W that is useless to us.  I don't want to have to install another brand of router, but as the client NEEDS a VPN client supported router, I am going to have no choice!!
aushardworking Thu, 03/08/2012 - 02:08
THANKS!!  That did the trick!!
Also  - Slightly off topic, is there anyway I can see ADLS connection stats, like connection time etc??
Andrew Hickman Thu, 03/08/2012 - 02:11
Hi John,
Yes - this is on a hidden page.  Once you log in to the GUI, change the URL page name to "dsldiag.asp".
Andy
aushardworking Thu, 03/08/2012 - 02:47
Hi Andy,
Thanks again!!  Tricky
I am struggling to understand the output though...  I am looking for how long the connection has been established.
Here is my output...
xdslctl: ADSL driver and PHY status
Status: Showtime
Retrain Reason:          8000
Max:          Upstream rate = 1053 Kbps, Downstream rate = 10524 Kbps
Path:          0, Upstream rate = 1017 Kbps, Downstream rate = 8930 Kbps
Link Power State:          L0
Mode:                              ADSL2+
Trellis:                    U:ON /D:ON
Line Status:                    No Defect
Training Status:          Showtime
Down                    Up
SNR (dB):           6.4                     6.1
Attn(dB):           46.0                     24.5
Pwr(dBm):           19.2                     12.3
ADSL2 framing
MSGc:                    52                    17
B:                    61                    30
M:                    4                    1
T:                    5                    3
R:                    6                    6
S:                    0.8857                    0.9641
L:                    2294                    307
D:                    64                    8
Counters
SF:                    159367                    153893
SFErr:                    11                    5
RS:                    11554168                    2025120
RSCorr:                    2146                    74
RSUnCorr:          93                    0
HEC:                    10                    8
OCD:                    0                    0
LCD:                    0                    0
Total Cells:          53898174                    2482803660
Data Cells:          1583387                    320185129
Drop Cells:          0
Bit Errors:          0                    652920
ES:                    6                    3
SES:                    0                    0
UAS:                    42                    42
AS:                    2559
INP:                    0.66                    0.62
PER:                    16.05                    16.63
delay:                    14.17                    1.92
OR:                    28.90                    11.06
Bitswap:          0                    602
Andrew Hickman Thu, 03/08/2012 - 08:15
Hi John,
Sorry, I don't believe that this information is available on that screen (or elsewhere in the device).
Andy
anufriev_dmitriy Thu, 12/27/2012 - 02:42
Hi!
Do you plan to support pptp client via wan adsl port?
In "mobile network" section pptp client is built-in, but in adsl "internet setup" section pptp client is not available.
Our company also REALLY need the vpn client support in SRP527W!  But not IPSec vpn. Many remote clients(points of retail outlets) connects to corporate pptp server. We planned that SRP would initiate connection to pptp server. But SRP initiate pptp connection only via USB 3G backup WAN interface. Via primary interface (adsl) SRP don't initiate pptp tunnel - this functional is absent...
Please add to roadmap possibility of initiating pptp session on the adsl interface.
We don't want to have to install another brand of router's, to the other brands no trust...
