password management for WebVPN using ACS internal database
Mar 9th, 2010
Hello. Did anybody successfullylly implemented password management feature for ASA WebVPN clients using ACS internal database? I am stuck here trying to do so. Once it's enabled the authentication fails and clients can not longer vpn in.
Jagdeep Gambhir Tue, 03/09/2010 - 17:32
  • Red, 2250 points or more
Acs doesn't support 'password aging using ACS internal database.
~JG
Do rate helpful posts
jrabinow Tue, 03/09/2010 - 23:04
  • Cisco Employee,
Which ACS version are you using? Password aging is supported in ACS 5.1
20vek Wed, 03/10/2010 - 07:17
is there specific radius attributes that I need to configure?
20vek Wed, 03/10/2010 - 05:23
Your information is outdated. It does in 5.1
