Alias Rename Not Saving
Mar 9th, 2010
I am trying to rename a device alias on and MDS 9000 series SAN Core Switch in Fabric Manager. When I click on it to make the change, it takes it. Then I save it. When I exit out and come back in, the change is new name change reverts back to the original.
When I change the name, the new name is bolded so I know it's a case where a change has been made but not applied.
Any ideas on what I'm doing wrong?
User_4444_2 Fri, 03/12/2010 - 03:20
Is it the same from the CLI? Do you get prompted to save the changes when
you exit Fabric Manager?
edrichard Mon, 03/15/2010 - 07:48
Thanks for the replies...
Will try the CLI and let you know how it turns out.
Ed
Trending Topics: Storage Networking
