Mar 10 08:07:19.910 CCT: %BIT-4-OUTOFRANGE: bit 3071 is not in the expected range of 1 to 255 -Traceback=
Mar 9th, 2010
Hi NetPro.
Anyone encountered this before ?What is the means for the below msg ? currently user complaint about the Network Slowness . i found this logs from the switch.
-Traceback= 1CB822C 1CB8978 10243DC 1024930 11C03EC 11C75FC 11C32A0 239BB80 2370828 2361194 238BEBC 1A295A8 1A20078
your reply will be highly appreciated.
Thanks a lot.
Overall Rating: 2 (3 ratings)
Ganesh Hariharan Tue, 03/09/2010 - 20:29
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hi NetPro.
Thanks a lot.
Check out the link regarding the error hope that helps :-
http://www.ciscosystems.com/en/US/docs/ios/12_3/sem1/system/messages/emgbgp.html
Ganesh.H
ngengyeong Tue, 03/09/2010 - 20:32
Hi Ganes.
Ya ! i have checked before i posted . basically the link doesn't really explain ...
coz, this logs keep generating from the switch ... however other cascaded switches have no such log ..
BIT Messages
The following are dynamic bitlist messages.
Error Message
%BIT-4-OUTOFRANGE  : bit [dec] is not in the expected range of [dec] to [dec]
Explanation   An invalid request was detected by the bit list subsystem.
Recommended Action   Copy the error message exactly as it appears on the console or in the system  log. Issue the show tech-support command to gather data that might help identify the nature of the  error. If you cannot determine the nature of the error from the error message text or from the show  tech-support command output, contact your Cisco technical support representative and provide the  representative with the gathered information.
Ganesh Hariharan Tue, 03/09/2010 - 20:47
Hi Ganes.
BIT Messages
#Error Message
What is the switch model and ios version in which you are getting this error messages
Ganesh.H
ngengyeong Tue, 03/09/2010 - 20:50
Hi Ganesh.
i am using C3560 . and Version 12.2(50)SE3.
Switch#sh hard
Cisco IOS Software, C3560 Software (C3560-IPBASEK9-M), Version 12.2(50)SE3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 22-Jul-09 06:41 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02900000
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
Switch uptime is 4 weeks, 3 days, 20 hours, 58 minutes
System restarted at 15:50:33 CCT Sat Feb 6 2010
System image file is "flash:c3560-ipbasek9-mz.122-50.SE3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C3560-24PS (PowerPC405) processor (revision R0) with 131072K bytes of memory.
Processor board ID FDO1225X1JS
Last reset from power-on
2 Virtual Ethernet interfaces
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:22:0D:B5:0F:80
Motherboard assembly number     : 73-9673-10
Power supply part number        : 341-0029-05
Motherboard serial number       : FDO12250ANN
Power supply serial number      : DTN1222425P
Model revision number           : R0
Motherboard revision number     : A0
Model number                    : WS-C3560-24PS-S
System serial number            : FDO1225X1JS
Top Assembly Part Number        : 800-25861-05
Top Assembly Revision Number    : A0
Version ID                      : V07
CLEI Code Number                : COMUY10ARA
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 26    WS-C3560-24PS      12.2(50)SE3           C3560-IPBASEK9-M
Configuration register is 0xF
Ganesh Hariharan Tue, 03/09/2010 - 21:25
Following was the bug id which was resolved in Cisco IOS Release 12.2(46)SE:
CSCso66528
When an interface configured with port security reloads or you clear an error-disabled condition, the interface no longer returns this traceback message:
%BIT-4-OUTOFRANGE: bit 0 is not in the expected range of 1 to 4095
and i dont find any bug related to this error in th running ios in cisco site also,check out the below link hope that helps
http://www.cisco.am/en/US/docs/switches/blades/3110/software/release/12.2_46_se/release/notes/OL16969.html
Ganesh.H
ngengyeong Tue, 03/09/2010 - 21:33
Hi Ganesh.
Thanks for your information. basically our switchport configured port-security as well. however i don't see any problem for the switch configuration. just that i wondering what could be caused the network slowness now. i've checked the spanning tree and cpu util so far everything looks good. besides this logs i don't see anything then.
thanks a lot.
