CUE Stuck in Halt state, can't load boot file
Mar 9th, 2010
Hi Everyone,
I was trying to upgrade the CUE installed package from 3.1 to 3.2.1. But it did not complete successfully and then when I tried to reload the CUE it stuck in halt state and unable to load. I can login in to boot loader mode only. How to reload CUE with the previous image???
Can anyone help me with this?
Thanking you in anticipation.
Amit.
paolo bevilacqua Wed, 03/10/2010 - 03:12
  • Hall of Fame,
    Founding Member
Donwload the "installer" image, place with all the other files on a system that has both TFTP and FTP servers enabled.
In  boot mode, do config and set all parameters needed.
Then do "boot tftp". That will begin a fresh installation.
amitkumarp Wed, 03/10/2010 - 08:57
Hi  p.bevilacqua
I tried to do the same, but I couldnt load 3.2.1 image so I have loaded the image 3.1.1.
But it is not compatible with our CUCM 7.1. So I need to upgrade it to 3.2.1.
I have gone through the documents from Cisco and following it so I think it should be done by tomorrow morning.
Thanks for your reply.
Amit.
