Ethernet to Gigabit port converter for Cisco 3560?
Answered Question
Mar 10th, 2010
We have two buildings which are connected by OFC. I have a Cisco 3560 switch where all my vlan configuration is done. I need all vlan's to be available in our second building also. But I think we need a Giga port to communicate between the ofc-ethernet converters in the two buildings.
Is there a converter to convert an ethernet port in cisco 3560 to Gigabit port so that I can make this port trunk and get all vlan info in the second building?
Appreciate any response.
Thanks in advance.
Ribin Jones S.B
Correct Answer by cdelafuente31 about 6 years 11 months ago
You can use the copper SFP + media converter or the F.O SFP without media converter. I.E.:
3560 - SFP (1000BASE-T) ---------- Media converter ------ F.O.------ Media converter ------- Cisco 500
3560 - SFP (1000BASE-LX or SX) ---------- F.O. ------------ Media converter ------- Cisco 500
If you choose the second option, the protocol used by the SFP (1000BASE-SX, 1000BASE-LX…) must match with the one used by the media converter in the other end.
You won’t have any problems with VLANs regardless the SFP you choose.
Best regards,
Overall Rating: 5 (1 ratings)
cdelafuente31 Wed, 03/10/2010 - 03:16
Hi Ribin,
I don't know a port converter for Cisco 3560, but I think that a possible alternative is a 10/100BASE-T/100BASE-FX media converter instead the 1Gb media converter. I think these converters aren't very expensive.
Best Regards,
César.
Ganesh Hariharan Wed, 03/10/2010 - 03:31
Thanks in advance.
Ribin Jones S.B
Hi Ribin,
Check out the below link hope to help!!
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750e_3560e/hardware/install/notes/1757202.html#wp92781
Ganesh.H
ribin.jones Wed, 03/17/2010 - 02:24
Thanks for the replies.
I have 2 SFP ports in this switch and these are shown as GigabitEthernet0/1 and GigabitEthernet0/2 as I run sh ip int brief. What can I do with this?
- Ribin
cdelafuente31 Wed, 03/17/2010 - 02:45
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
You can install a GLC-T= (1000BASE-T SFP transceiver module for Category 5 copper wire)
But if you can install two GLC-SX-MM= (or the single mode version, it depends the FO you have installed), one in each edge switch, you don’t have to use the media converter.
Best regards,
ribin.jones Wed, 03/17/2010 - 03:32
So, I need to use GLC-T= (1000BASE-T SFP transceiver module for  Category 5 copper wire) or the module for Optical wire?
In the other end, I have a media converter and the out is connected to the Cisco 500 series Express switch.
My thinking is that, if I use the transeiver module in the L3 switch end, I can make this port trunk and get all vlan info to the Cisco Express 500 series switch. Am I correct? Please correct me if I am wrong.
- Ribin
Correct Answer
cdelafuente31 Wed, 03/17/2010 - 04:07
Best regards,
