Martin Ermel Wed, 03/10/2010 - 08:25
  • Blue, 1500 points or more
I definitely would not update apache because you would loose Cisco TAC support. If you see any problems, open a TAC Case and request a patch. I can remember onetime in the past which updated apache.
kerklaanm Thu, 03/18/2010 - 06:25
It turns out this vulnerablity does not affect LMS.
This issue is not affecting the LMS.
Please have a look at the following bug ID.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtf54872
as you can see as I suspected we are not using This module in the LMS.
So as a workaround you can safely comment the line
LoadModule isapi_module modules/mod_isapi.so
From httpd.conf file.
Regards Marco.
yjdabear Thu, 03/18/2010 - 06:40
  • Gold, 750 points or more
On LMS 3.2, the only httpd.conf I can find is /opt/CSCOpx/MDC/Apache/conf/httpd.conf, which has no mention of "LoadModule isapi_module modules/mod_isapi.so" at all.
Related Content
