Fax Machine Issue on VG224
Mar 10th, 2010
Am having an issue with a fax machine that is attached to our VG224. When you log into Call Manager it is not showing as registered on the VG224, i have reset and restarted it via Call Manager but no joy, I have also try using another port but it is not working either. Any ideas?
Overall Rating: 1 (1 ratings)
Paolo Bevilacqua Wed, 03/10/2010 - 03:08
At very least, you need to mention which protocol you are using between CM, VG224, and PSTN GW
neerajdirect Wed, 03/10/2010 - 03:40
Sorry about the rating ...I was showing someone the new rating system.
And he clicked on one star.
This was accidental is there a way to revert this ?
Paolo Bevilacqua Wed, 03/10/2010 - 03:44
It is not a good system, single-click operation leads to frequent mistakes.
You can only rate other posts to compensate.
