Adding a partner server to Unity
Mar 10th, 2010
What is the preliminary steps or step by step instructions on adding an exchange partner server to Unity?
I don't seem to find anywhere on Cisco site for this? Any links will be helpful.
Aaron Harrison Wed, 03/10/2010 - 06:04
  • Community Spotlight Award,
    Member's Choice, May 2015
Your Unity server will have one partner server, so you don't add one, you change it.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/upgrade/guide/ex/5xcuruge050.html#wp1158133
If you just mean add a new server which can contain subscriber mailboxes then you just need to run the Perms Wizard to set permissions on the mailbox stores on the new new server:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/upgrade/guide/ex/5xcuruge120.html#wp1104101
Aaron
Please rate helpful posts...
