What's the latest firmware for LinkSys SPA8000 ATA ?
Mar 10th, 2010
We have 6 SPA8000 ATA LinkSys boxes and are having a variety of issues (below) trying to deploy them -- what/where is the latest version of the firmware for these boxes?
The current version (5.1.10) as these issues (incomplete list and in no particular order):
* one unit changed its LAN address from 192.168.0.1 to 198.168.1.1 even though this is apparently unchangeable... at least, a reset from an analog port worked.
* setting VLAN to 0x10 is not the same as 16 (even the on-screen info reads "[0x000-0xFFF]" -- go figure)
* settings can't be reliably unset -- clearing settings (extension, password, name) does nothing -- extension stays registered until the PBX/Proxy address is cleared.
* re-using a SPA8000 which was used as a test unit to a test Switchvox; changing an extension's parameters "looks" OK on the web interface -- BUT, the extension, while pointed to the production Switchvox according to the display, is still pointing to the test system.  Changing the Proxy(PBX) address has no effect -- no matter what I set it to, Switchvox diagnostics gets this wrong IP from the SPA8000:
SPD_E_INVALID_TYPE~~ 10.35.3.2     Using a numeric IP address instead of a canonical one, the extension finally registers.
