Shared line and Single Number reach (SNR)
Mar 10th, 2010
I am after a bit of guidance if people can help me please.
I have a small office that has a single incoming number 30000
Which orignally was a shared line on the three office phones.
The office isn't maned all the time so I descided to use SNR to send calls to 30000 on to two mobile phones.
I couldn't get this to work without stopping the shared line set up.
SNR now forwards to the two mobile phones correctly but the 2 voip phones have no idea that 30000 is ringing.
Any one got any ideas, how a can get it so I have the three VoIP phones ringing and the two mobile by using shared loine and SNR.
Other requirement is any unanswered calls need to go to voice mail box 30000
Brandon Buffin Wed, 03/10/2010 - 07:36
  • Purple, 4500 points or more
Instead of using a shared line on all phones, setup a broadcast hunt group to send incoming calls to the extensions on the 3 phones. You can then leave your SNR config in place on one of the DNs.
Hope this helps.
Brandon
martinbuffleo Wed, 03/10/2010 - 07:56
Brandon thanks for the reply
Have put the SNR on the 30000 then then reconfigured the shared line settings and that appears to have worked.
Bit of a pain trying to work out the answer too late times when connecting to mobiles but such is life
Tommer Catlin Wed, 03/10/2010 - 09:39
  • Green, 3000 points or more
This is by design.  SNR is only designed to use an external number, not another DN on the CUCM.
