LMS 3.2 vlan configuration
Mar 10th, 2010
I have some port to configure to have a vlan + a voice vlan. How can i do that using LMS 3.2 ?
I have check the vlan port assignement but i haven't seen a option to define 2 vlan.
typically our port are configure like this one
interface FastEthernet0/1/1
switchport access vlan 2
switchport voice vlan 100
macro description cisco-phone | cisco-phone
spanning-tree portfast
and i wish to use LMS to configure new port.
Cheers
Joe Clarke Wed, 03/10/2010 - 11:20
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can use Netconfig in RME to do what you want.  RME 4.3 has port-based Netconfig functionality which will greatly facilitate what you want to do.  Just create a new Netconfig port-based job, and create a new Adhoc task to specify the configuration you require.
MathieuJM_2 Thu, 03/11/2010 - 08:01
Is there really no way to do it using a GUI ?
How should i simply wish interface i wish to configure ?
Joe Clarke Thu, 03/11/2010 - 09:51
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Netconfig is all GUI-based.  I don't understand the question.
MathieuJM_2 Fri, 03/26/2010 - 06:32
What i mean is that can i have a gui that let me choose which vlan
i wish to add to port ?
we have different voice vlan and different data vlan, can i have a gui that let me choose one of the data vlan and optionnaly a voice vlan ?
i don't understand how to do that
Joe Clarke Fri, 03/26/2010 - 11:06
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This feature is not available on Campus yet, and there isn't another GUI in LMS which will provide this.  I have opened a feature request, CSCtf51757, but you should talk to your account team to get them to push things from the business side as well.
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
MathieuJM_2 Fri, 04/09/2010 - 03:33
thanks for this request from your part.
In order to be able to configure the port of my switch with my configuration VLAN voice + VLAN data, how do i must use the netconfig tool ?
Can you help me creating the right job that eventually let me enter the port of the switch as a variable ?$
Joe Clarke Fri, 04/09/2010 - 23:27
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I think what might be easiest is to go to RME > Config Mgmt > Netconfig > Netconfig Jobs, and create a new Port-based job.  Then, define an ad-hoc rule to match the port or ports you want.  For example:
Port.PortName equals Fa0/3
Then, create an Adhoc Task which defines the VLAN values that you require.
Related Content
