Router Upgrade
Mar 10th, 2010
I am in the process of planning an router upgrade running CCME/CUE AIM.  I am currently running 12.3(11)T11 CME3.2/CUE2.1.3 IPVOICE feature pack and would like to upgrade to 12.4(15)T with the latest version of CME and CUE available for that ios version.
If there is a later version of the IOS,CME,CUE that will run on my router I would like that.  Basically want to updgrade to the newest version that will run on my router.
We are also installing a new 1GB AIM module to the router.  It currently has an AIM-CUE in it. The router is a 2651XM.
I need to find a good upgrade guide that will quide me through the upgrad process.  I have been unable to find one on
Also, please advise me to the latest version that will run on my router.
Attached is a sh ver, and sh diag
Overall Rating: 5 (1 ratings)
Aaron Harrison Wed, 03/10/2010 - 08:13
See this link for a mapping of IOS to CME versions:
Click on the links to the right and scroll to the bottom to see which platforms are supported - 2651xm isn't supported for some newer versions.
When you decide which version to upgrade to, check your CUE compatibility to determine which versions you can/should run, and whether you need to upgrade Unity first:
Upgrading CME is basically a matter of upgrading your  IOS, and upgrading firmware and GUI files in accordance with what's listed on the links above. There should be a bundle download zip that includes all the GUI and firmware files.
Please rate helpful posts...
Related Content
