Global Subscriber Manager error - VB.UserControl
Mar 10th, 2010
While trying to start the GSM tool, it does not start and I see this in the logs:
[mdlUnityDatabase]determineBridgeNetworking_0 Start: 42437.08 End: 42437.08 - Elapsed: 0.0
11:47:17   ERROR:(                                [mdlMain]Main)   Err.Number = 374 Err.Description = Failed to activate control 'VB.UserControl'.  This control may be incompatible with your application.  Make sure you are using the version of the control that was provided with your application. Line: 430
11:47:17    Info:(                                [mdlMain]Main) Exiting  [mdlMain]Main_0 Start: 42436.73 End: 42437.11 - Elapsed: 0.375
Trying to run on two different Unity servers, both are version 7.0(2).
David Hailey Thu, 03/18/2010 - 23:09
  • Purple, 4500 points or more
My first step would be to update the GSM tool to the latest version.  If you still have problems, let me know and we'll go from there.
Hailey
Please rate helpful posts!
crowda Thu, 07/29/2010 - 08:07
I'm getting this same error.  I have updated GSM.
Does anyone know how to resolve it?
t.a.bennett Mon, 10/11/2010 - 02:51
Anybody get a fix for this in the end, just installed GSM on a fresh Unity 8 system and getting the same error. This is with the latest downloaded version of GSM
Tom.
Ignore me, I'm having a Monday morning moment, it's not supported on Unity8 :-)
