DST for callmanager version 6.1
Mar 10th, 2010
Folks:
customer has callmgr  System version: 6.1.2.1117-1.
will this version handle this weekend's dst change or is a workaround/fix required?
where can i find information ?
thanks
Rob
Rob Huffman Wed, 03/10/2010 - 09:37
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Rob,
CSCsy33379 addresses version 6.x and shows the "fixed-in" version as 6.1(2.1139.1). I would open a case with TAC to see what is "concrete" for 6.1(2). Also have a look at this excellent doc from Wes Sisk @ Cisco
https://supportforums.cisco.com/docs/DOC-6199
Hope this helps!
Rob
rvincent Wed, 03/10/2010 - 09:49
Rob
thanks for links
looks like our version 6.1.2(1117-1) is not fixed if its first fixed in version 6.1.2.1139-1,
Rob
Rob Huffman Wed, 03/10/2010 - 10:14
  • Hall of Fame,
    Founding Member
Hey Rob,
You are most welcome
Cheers!
Rob
Rob Huffman Thu, 03/11/2010 - 08:53
  • Hall of Fame,
    Founding Member
Hey Rob,
Just thought you might want to see this new doc that just went up
a few minutes ago (Thanks Wes!)
Daylight Savings Time (DST) during Spring 2010
https://supportforums.cisco.com/docs/DOC-8814
It does show that the fixed in version that we spoke about is an Engineering
Special
Cheers!
Rob
