Gig Capabilities
Answered Question
Mar 10th, 2010
I have a 6509 with serveral WS-X6748-GE-TX cards in it. How many ports can actually be used for Gig?
Correct Answer by Ganesh Hariharan about 7 years 2 weeks ago
You can use available 48 ports on the blade or module as WS-X6748-GE-TX is high-performance 48-port 10/100/1000 Ethernet over copper module designed specifically for use with the Cisco Catalyst 6500 Series Supervisor Engine 720 in data center and distribution layer deployments.
The WS-X6748-GE-TX features a 40-Gbps interconnection to the Cisco Catalyst 6500 Series Supervisor Engine 720's switch fabric-ideal for high-demand, high-density Gigabit Ethernet requirements across all 48 ports.
Hope to Help !!
Remember to rate the helpful post
Ganesh.H
Overall Rating: 5 (1 ratings)
Reza Sharifi Wed, 03/10/2010 - 09:44
  • Cisco Designated VIP,
    2017 LAN
They all can be used but there is oversubscription, because each line card supports maximum of 40Gig
Reza
dasmith58 Wed, 03/10/2010 - 09:47
That's what I was thinking. I use to use one in every 8 or 10 ports as Gig. I that still a good practice?
Reza Sharifi Wed, 03/10/2010 - 10:00
    2017 LAN
Why not use the ports as Gig?  You are not going to have 48 Gig ports sending traffic at the same time.  And if your are really concern about that just use 40 Gig ports out of 48 instead of 1 out of 8 or 10.
Reza
Jon Marshall Wed, 03/10/2010 - 10:02
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Just to add to Ganesh's post.
The WS-X6748-GE-TX supports 48Gbps ports and has a 40Gbps connection to the switch fabric. So you could actually use 40 ports without oversubscription although you would need to split it up as 20port per port group. So 1 in 8 or 1 in 10 is not really utilising the full capacity. Note 1 in 8 would be good for a WS-X6548-GE-TX because this only has a 8Gbps connection to the switch fabric.
Also it is unlikely that you will manage to get all 48 ports transmitting at a full 1Gbps at the same time so you can probably go ahead and utilise all 48 ports.
Jon
Correct Answer
Ganesh Hariharan Wed, 03/10/2010 - 09:49
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hope to Help !!
Ganesh.H
