Using DBAdmin to backup to external FTP server
Answered Question
Mar 10th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
I am trying to script an automatic FTP backup of a WCS system using the DBAdmin command from a command line.
As the WCS was previously a WLSE it is running Linux via the WSC conversion part code WCS-WLSE-APB-100, it has then been further upgraded and is running 6.0.170.0 Base. Linux version is: 2.6.18-8.el5 ([email protected]) (gcc version 4.1.1 20070105 (Red Hat 4.1.1-52)) #1 SMP Fri Jan 26 14:15:21 EST 2007)
When I execute the command I get the following:
[[email protected] bin]# ./dbadmin.sh remotebackup 10.0.0.1 test test
Do you want to backup report history? (y/n) n
Report history will not be backed up.
Exception in thread "main" java.lang.IllegalArgumentException: Path must not be empty
        at org.apache.commons.io.FileSystemUtils.freeSpaceOS(FileSystemUtils.java:190)
        at org.apache.commons.io.FileSystemUtils.freeSpaceKb(FileSystemUtils.java:166)
        at com.cisco.server.util.FreeSpaceChecker.freeSpaceGB(Unknown Source)
        at com.cisco.server.util.FreeSpaceChecker.checkDirectoriesForBackup(Unknown Source)
        at com.cisco.packaging.SelectDirAndBackupDb.backupDatabase(Unknown Source)
        at com.cisco.packaging.SelectDirAndBackupDb.remoteDatabaseBackup(Unknown Source)
        at com.cisco.packaging.DBAdmin.remoteBackup(Unknown Source)
        at com.cisco.packaging.DBAdmin.runMain(Unknown Source)
        at com.cisco.packaging.DBAdmin.main(Unknown Source)
Any ideas where I am going wrong or could anyone suggest an alternative method of backing up the WCS backups off this appliance to a different host?
Correct Answer by sschmidt about 7 years 4 months ago
Found it.  Works in mine because this bug is in your code .170 and not mine .181.
CSCte81786   dbadmin remotebackup generates errors, does not do ftp backup.
An upgrade should help
Overall Rating: 5 (1 ratings)
sschmidt Wed, 03/10/2010 - 10:28
  • Cisco Employee,
Seems to work fine for me:
nms-xx:/opt/WCS6.0.181.0/bin# ./dbadmin.sh remotebackup 64.x.x.x spschmidt xxxxxx
Backing up the database ... to Temp/1268245111903
Database backup initiated.
Copying extra files ...
Database backup done.  Taring the backup files ...
Backup succeeded
Backup resides on host=64.x.x.x dir=/remote_nms//opt/WCS6.0.181.0/webnms/Temp/nms_backup_of_wcs.nmsbackup
Can you add a cat of /etc/redhat-release to the post
erick.whiteford Wed, 03/10/2010 - 11:30
Output of the command you suggested is:
[[email protected] etc]# cat redhat-release
Red Hat Enterprise Linux Server release 5 (Tikanga)
Good to hear it works for you as it gives me some hope of finding the solution. All documentation regarding the dbadmin command refers to v4.1 and I was wondering if it had been depreciated from later versions!
Correct Answer
sschmidt Wed, 03/10/2010 - 11:40
  • Cisco Employee,
erick.whiteford Wed, 03/10/2010 - 11:55
Thanks for the answer and quick response. An upgrade appears the way forward.
Kind regards
Related Content
Trending Topics - Security & Network
