unable to establish vpn error with anyconnect
Mar 10th, 2010
I'm using the cisco anyconnect client and when forming a connection I recieve "unable to establish vpn". However, the ASA shows me being authentacted to the Clientless portion of the ssl VPN. The command I'm running is show vpn-sessiondb webvpn (show's the clientless connections) .  The show vpn-sessiondb svc (shows clients connection) doesn't show anything.  I looked at my configs and they seem clean and not to mention this was working before!!
Has anyone seen this before? I guessing maybe it's the profile that's created for the ssl connection - maybe it's FUBAR or the asa is just FUBAR and may need a reboot.
Overall Rating: 4 (1 ratings)
johnd2310 Wed, 03/10/2010 - 15:17
What antivirus or firewall are you running on your PC.
John
DialerString_2 Wed, 03/10/2010 - 15:23
Thanks for your reply, John. I'm not running any virus software and the firewall has been disabled on the box. Which is running server 2003.
DialerString_2 Thu, 03/11/2010 - 07:11
Resolved....My boss actually figured in out. Turns out the ssl certificated expired and once he uploaded the new on to the ASA it started working.
