Problem with C2811-15UC/K9
Mar 10th, 2010
I'm having a problem with a Cisco 2811 UC Bundle. I installed it and immediately upgraded the IOS as well as the CUE to the newer version 7.1. Telephony is working great, however when I tried to activate the mailboxes it tells me that I have no mailboxes available on the CUE.
I figured it would be a PAK issue, so I looked through all the documentation that came with the router, and the only PAK I found was the Call Connector which obviously does something else. I investigated a little further and it turns out that the bundle comes with the CUE/UCME prepacked and ready to go, much like Plug & Play.
So If I downgrade the IOS and the CUE to factory settings, will everything be available as it came in the original Bundle, or is there a special type of IOS/CUE Bundle firmware I must download?
Overall Rating: 5 (1 ratings)
josmartinezits Thu, 03/11/2010 - 06:58
The easiest solution I seem to have right now is downgrade the CUE since it came originally with the 3.1. I will try that and let you know.
Thank you very much!
Related Content
