Cisco ASA 5520 SSL VPN Web Login Customization For RSA Login
Mar 10th, 2010
I have a Cisco 5520 that I have RSA radius with hardware token up and working witrhout issue. The RSA radius authentication works fine.
My problem is that I want the login page of the WebVPN portal to display two fields for the user RSA passcode. An RSA passcode is the PIN and the current toke code together.
I want one field to accept the PIN from the passcode and the other field to accept the TOKEN CODE from the RSA token.
Currently the login page has in this order:
USERNAME:
PASSCODE:
My end state would be:
USERNAME:
PIN:
TOKENCODE:
I know this has been done with the native Cisco IPSEC client but I cannot find a way to do this with the WebVPN login page. I have been thru the Customization page and can't seem to get this to work correctly.
Thanks.
alexdelangel Sun, 06/22/2014 - 16:32
Hello friend!
Please allow me to resurect this old post. Did you have the solution?
Regards!
