MCS7845-I3-IPC1 not compatible with 7.1(2-2b)
Mar 10th, 2010
Support matrix saying 'the MCS7845-I3-IPC1 as being compatible with versions 7.1(3-3b) and 8.0(1) only … NOT 7.1(2-2b) Is this for real?
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
The customer is trying to avoid going to 7.1(3) at this time because they don’t want to put the routers on IOS 15.   Can you confirm that this compatibility matrix is up to date.  Do you know why this particular platform doesn’t support 7.(2)?
Source: http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
Thanks in advance for advice.
Aaron
Overall Rating: 5 (1 ratings)
Rob Huffman Thu, 03/11/2010 - 06:01
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Aaron,
Cisco only tests and verify's certain hardware with certain releases and builds
the compatibility hardware check accordingly. This is why the newest hardware
server models will only be compatible with the newest CUCM releases
On this note however, your customer would not need to move their existing
routers/gateways to IOS 15(x). CUCM 7.1(3) was tested with and is also
supported on 12.4(20)T. I would go with 7.1(3x) here for stability anyway's.
Cisco Unified Communications Compatibility Tool
http://tools.cisco.com/ITDIT/vtgsca/VTGServlet
Cheers!
Huff
David Hailey Thu, 03/11/2010 - 13:13
  • Purple, 4500 points or more
Yeah, to follow up on Rob's note on the IOS versioning.  I'm not sure where you got this information about IOS 15 being needed for CUCM 7.1(3).  This is not true.  I am currently recommending 7.1(3b)SU2 to customers and, depending on features needed, have had good success running 12.4(20)T IOS for ISR voice gateways although, in some cases, you may need/want to consider the 12.4(24)T code.  Nonetheless, on the CUCM side - the 7.0 and 7.1(2) releases were a bit buggy IMO.  However, 7.1(3) seems to be bringing things back on track.
Hailey
Please rate helpful posts!
Related Content
