Warning message
RV042 Router
Mar 10th, 2010
we have a RV042 wan router. The  router documentation says that the NAT can be done in One-to One and  Many- to- One.
But in the Router web management I  can only see the One to one option. There is not One to Many option.  Our ISP has provided us with 14 available IP.
But we need to use one or all the 13 IP and NAT  it to many users within a pool.
lifennel Fri, 03/12/2010 - 09:56
Good afternoon,
The RV042 is capable of rules that map multiple public IP addresses in a range to multiple private IP addresses in a range. This should be available once you check the "enable" checkbox on your RV042.
Ensure you have the newest firmware of 1.3.12.19-tm
I will try to locate a RV042 and upload screenshots of what this looks like. I do not see that the documentation specifcally state that one-to-many is available, but that type of option is available under the one-to-one section.
I hope you found this helpful.
-Lindsey
