WRVS4400N - can't update firmware
I deeply regret having purchased a WRVS4400N less then a year ago.  I have the crappy v1 model with
firmware  V1.1.0.3.  I have downloaded from cisco WRVS4400N support page wrvs4400n_v1_fw_v1.1.13.zip
but I can't update the firmware from a wired connection.
My router stop functioning about every 12-20hrs. (wireless and sometime wired.)  I need to reboot the router on a daylie basis.
I did some basic configuration:
-wireless configuration with mac filtering.
-ip reservation to mac.
-disabled ips (was slowing down my internet connection by 50%.)
When I try to update the firmware I get :
Upgrade file is not the correct type or version for this device.
Upgrade  failed.
Please obtain the correct file and try again.
I'm confused. What a piece of junk!
Thanks to anyone that can help me with this problem / Anyone can recommend a good wireless router for about 300$?
A
josruiz Thu, 03/11/2010 - 06:34
Mr. Alex,
Best way to tacle this issue is if you contact us, we have access to make some changes in your router, and update the firmware.
Almost 98% of the time the latest firmware will carrect this problem, if you will please call at 1866-606-1866 US/ Canada.
