SSL VPN (WebVPN) issues with IOS 15.0(1)M1
Mar 11th, 2010
Hello everyone... I need your help!
I am having some weird issues with webvpn/anyconnect, please find the relevant information below;
- AnyConnect Client prompts users with the following error:
"The secure gateway has rejected the agent's VPN connect or reconnect request. A new connection requires re-authentication and must be started manually. Please contact your network administrator if this problem persists."
Mar  5 13:09:45:
Mar  5 13:09:45: WV-TUNL: Tunnel CSTP Version recv  use 1
Mar  5 13:09:45: WV-TUNL: Allocating tunl_info
Mar  5 13:09:45: WV-TUNL: Allocating stc_config
Mar  5 13:09:45: Inserting static route: SSLVPN-VIF36 to routing table
Mar  5 13:09:45: WV-TUNL: Use frame IP addr ( netmask (
Mar  5 13:09:45: WV-TUNL: Tunnel entry create failed:IP= vrf=77 session=0x67234340
Mar  5 13:09:45: HTTP/1.1 401 Unauthorized
Mar  5 13:09:45:
Mar  5 13:09:45:
Mar  5 13:09:45:
Mar  5 13:09:45: Deleting static route: SSLVPN-VIF36 from routing table
Mar  5 13:09:45: WV-TUNL: Failed to install (addr, table_id 77) to TCP
Mar  5 13:09:45: WV-TUNL*: Received server IP packet 0x6692EB08:
Mar  5 13:09:45: WV-TUNL: CSTP Message frame received from user usr-test (
WV-TUNL:      Text: HTTP response contained an HTTP error code.
Mar  5 13:09:45: WV-TUNL: Call user logout function
Mar  5 13:09:45: WV-TUNL: Clean-up tunnel session (usr-test)
When the error occurs, the "SVCIP install TCP failed" counter increments:
VPN-Router1#  show webvpn stats detail context CUSTOMER-VPN
Tunnel Statistics:
    Active connections       : 1
    Peak connections         : 3          Peak time                : 19:09:04
    Connect succeed          : 9          Connect failed           : 5
    Reconnect succeed        : 0          Reconnect failed         : 0
    SVCIP install IOS succeed: 14         SVCIP install IOS failed : 0
    SVCIP clear IOS succeed  : 18         SVCIP clear IOS failed   : 0
    SVCIP install TCP succeed: 9          SVCIP install TCP failed : 5
    DPD timeout              : 0
IOS Version Details:
Cisco IOS Software, 7200 Software (C7200-ADVIPSERVICESK9-M), Version 15.0(1)M1, RELEASE SOFTWARE (fc1)
System image file is "disk2:c7200-advipservicesk9-mz.150-1.M1.bin"
The router also runs IPSEC remote access VPN in addition to the webvpn/anyconnect scheme.
webvpn context CUSTOMER-VPN
title "SSL VPN for Customer"
ssl authenticate verify all
login-message "Enter username and passcode"
policy group CUSTOMER-VPN
   functions svc-required
   svc keep-client-installed
   svc split include
   svc split include
default-group-policy CUSTOMER-VPN
aaa authentication list AAA-LIST
aaa authentication auto
aaa accounting list AAA-LIST
gateway vpn virtual-host
logging enable
The error happens sporadically, at least once a week, and on different contexts. Does anyone have any clue on what can cause this issue? Any help is appreciated!
Andreas Reimann Mon, 06/14/2010 - 01:24
We encountered same issue very sporadically running IOS 12.4(24)T3 (ADV-IP-SERV) on 3825
It matches quite close your configuration. Did you opened already a Cisco TAC Case?
Atle Hardarson Mon, 06/14/2010 - 02:11
Do you allocate the AnyConnect client's IP-adresses via IP pools on your ACS server? If so, you can consider switching it to a local ip pool on the router. This seemed to have solved the problem for us.
Andreas Reimann Mon, 06/14/2010 - 02:25
Yes, we allocate addresses through ACS. Local IP adress assignment i consider as a workaround only.
Related Content
