FTP directory listing not working
Answered Question
Mar 11th, 2010
I have configured normal ACE 4710 in bridge mode and I have statically natted ACE VIP in firewall. But when I am doing FTP to ACE natted IP from outside network I can connect to any of the virtual server but when I run "ls", directly listing is not working.
Below is my ACE configuration.
access-list bpdu-fixup ethertype permit bpdu
access-list ALL line 8 extended permit ip any any
access-list ALL line 16 extended permit icmp any any
rserver host srv1
  ip address 172.16.20.1
  inservice
rserver host srv2
  ip address 172.16.20.2
  inservice
serverfarm host srv
  rserver srv1
    inservice
  rserver srv2
    inservice
sticky ip-netmask 255.255.255.255 address both SG1
  timeout 120
  serverfarm srv
class-map type management match-any remote-mgmt
  201 match protocol snmp any
  202 match protocol ssh any
  203 match protocol icmp any
  204 match protocol http any
  205 match protocol https any
  206 match protocol xml-https any
class-map match-all slb-vip
  2 match virtual-address 172.16.20.10 any
policy-map type management first-match remote-mgmt
  class remote-mgmt
    permit
policy-map type loadbalance first-match slb
  class class-default
    sticky-serverfarm SG1
policy-map multi-match client-vips
  class slb-vip
    loadbalance vip inservice
    loadbalance policy slb
    loadbalance vip icmp-reply
interface vlan 20
  bridge-group 1
  access-group input bpdu-fixup
  access-group input ALL
  access-group output ALL
  no shutdown
interface vlan 23
  bridge-group 1
  service-policy input remote-mgmt
  service-policy input client-vips
  no shutdown
interface bvi 1
  ip address 172.16.20.9 255.255.255.0
  no shutdown
ip route 0.0.0.0 0.0.0.0 172.16.20.254
What could be the reason of this issue?
Thanksm
Pawan
Correct Answer by Sean Merrow about 7 years 2 weeks ago
Hi Pawan,
Ideally, you want to accomplish your desired operation without using the any keyword.  The any keyword allows clients to connect to your rservers through the VIP via any protocol, which could be considered a security risk.  You should always try to lock your VIPs down to only the protocols that you intend to be load balanced.  So if you want to load balance only HTTP and FTP traffic on this VIP, then your config would look something like this:
class-map match-all ftp-vip
  2 match virtual-address 172.16.20.10 tcp eq ftp
class-map match-all www-vip
  2 match virtual-address 172.16.20.10 tcp eq www
  class class-default
  class ftp-vip
    inspect ftp
  <-- note that ftp inspection is only applied to FTP traffic
  class www-vip
You could always add the any class-maps back in and put it at the bottom of your multi-match policy to catch "other" protocols, but you should only do this if necessary.
Does this make sense?
Sean
Overall Rating: 5 (1 ratings)
Michael Berger Thu, 03/11/2010 - 06:27
  • Cisco Employee,
Hi Pawan,
At the moment you type "ls", the data connection will be opened. Usually ftp clients default to active ftp which means server will open the conenction.
I am not seeing NATing on the ACE: is the real able to reach the client?
Does it also fail with passive ftp?
Can you use a CLI ftp client and copy/paste what you get on console when trying to FTP to VIP?
Michael
Sean Merrow Thu, 03/11/2010 - 06:30
  • Silver, 250 points or more
I think this should work fine if you are using Passive FTP, so you might be using Active FTP.  If this is the case, you would need to use inspect ftp so the ACE can perform the needed fix-ups:
You Currently Have:
  class class-default
  class slb-vip
Add the Blue Highlighted Parts Below, and Test
  class class-default
  class ftp-vip
    inspect ftp  <-- note that ftp inspection is only applied to FTP traffic
  class slb-vip
Hope this helps,
Sean
winpwnkmr Thu, 03/11/2010 - 07:05
Thanks Sean it's working. But with my previous configuration I tried both the modes active and passive, nothing was working.
If I use whatever you suggested in that case can I use two different classes i.e. one for FTP and another for Web server (class ftp-vip & class-slb-vip)? If yes, the I have to put 2 match virtual-address 172.16.20.10 any I am not sure which will work for FTP too.
Pls. suggest.
Pawan
Correct Answer
Sean Merrow Thu, 03/11/2010 - 07:15
Hi Pawan,
  class class-default
  class ftp-vip
    inspect ftp
  class www-vip
Sean
